Bob Avellar
- May 25, 2001
Here's the scenario:
Car starts fine if I start it every day.
Car many times will not start after sitting through the weekend.
When it does not start it does have spark to the plugs.
Injectors are being pulsed as I have checked them with a light designed for the injector harness.
Fuel pressure gauge reads normal (45psi).
Car cranks but it makes no inkling of firing. Just cranks and cranks.
Mat sensor reads actual temp.
Water temp sensor reads actual temp.
I see the Cam sensor turning (must if the injectors are pulsing anyway, right?)
And the crank signal must be there if I have spark.
I am using a MAF T+ now but the problem was there before I made the change. It made no difference.
The ONLY known problem I have with the car is the check valve or maybe something wrong with the intank connnection to the fuel pump. I have done tests to determine why my fuel pressure only holds for about 20 minutes and pinching the FEED line near the tank is the only thing that helped to maintain pressure for any length of time. Actually it held only slightly longer and then it started going down as usual. When I release the pinched feed line the pressure drops 10 psi instantly.
OK, so everyone will tell me to drop the tank and fix or change the pump. I have a new one here ready to go in except I just put more gas in the tank the other day. Maybe that will solve everything but- I read normal pressure on the gauge (which I know to be dead on acurate. Can I be reading AIR pressure in the fuel line instead of actual fuel????
If I squirt some ether into the alky nozzle the motor tries to start. Usually after that it sometimes will start. Plugs don't get wet.
I have all new braided fuel lines, brand new filter (in the correct direction). It just doesn't make any sense to me at all and it's driving me nuts. Like I said maybe the new pump will cure everything but I can't understand it not starting with pressure at the end of the fuel rail and everything else normal. Car must get mad at me if I don't pay attention to it on a daily basis.
T+ does have security mode but when that is working the car will run for a few seconds-and the problem existed before i switched to the T+ anyway.
Any thoughts or ideas what else could possibly cause this problem or how I can have fuel pressure with no fuel even with pulsing injectors? Sounds like I'm asking for an aswer to a problem that can't happen-but that's why I'm so aggravated.
