I want to know if this is normal - the more my rpm climbs the richer the wideband # gets and the leaner the egt # gets? For ex: When I floor the car and lets say it is in first gear when the rpm hits about 4000 rpm and the boost reaches it's highest point which is 26.7 lbs the wideband reads 12.4 and the egt is at about 1400. When the rpm reaches 5400 rpm at 24.5 lbs boost the wideband reads 11.4 and the egt is 1704.
I have another question which I am wondering about. I inject the car with 95% ethanol and 5% water and I read once in a magazine that ethanol affects the wideband reading. For ex: If the wideband is reading 12.2 that means the actual wideband reading is about 11.5. Is this true?
Thanks for any replies, Marco.
86 Grand National t-top (60780km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3835lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs.
BEST E/T
60FT=1.55
1/8= 7.34
1/4= 11.59
MPH=118
BEST 60FT=1.52
BEST E/T
60FT=1.55
1/8= 7.34
1/4= 11.59
MPH=118
BEST 60FT=1.52
