Bob Avellar
- May 25, 2001
This is a 1 wire replacement alternator but i guess the small wire is supposed to be taped off and not used and the idiot light will no longer function. I don't mind the idea of the idiot light not being part of the charging circuit since when a bulb blows out or if it gets loose the alt won't charge. But I wonder if the ECM won't get voltage readings from the alternator and this would cause no readings or wrong readings when monitored by directscan. Also the voltage correction factors that the ECM might use for some functions would probably not work???? Or does the ECM get it's info from some other point? I don't know if any of these issues are valid concerns or not? Does anyone have any experience with this type of replacement alternator? I am not going to rebuild the one I have so I need to purchase one outright. Any ideas???? Here is the alternator.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7911982216&category=33573
