Pull the door panel, and grease the track. If it is still slow, even with the door panel off, then you probably need a replacement motor, and it will only be a matter of time before the motor stops working and you have to hit the inside of the door, just to get the window back up. The motors aren't too hard to put in, and usually come with pretty good iinstructions on how to do it.
