I did something dopey
I took mine off to fix the pump, I plugged it back in and it would not work.
I am not sure if you can see it but the 3 screws that bolt it to the firewall are the ground, there is a "strap" of sorts that goes from the motor internals to one of these screws.
I used my trusty dual alligator clip to clip to this "strap" and to a good ground and then it worked like a champ! I also tested the washer pump and it worked too! I did learn something: Don't stand outside the car and operate the washers or you will get soaked.
In other words I would check the grounds.
