Wires and vac lines stuff
Paul Clark
Dual gauge pod for the A pillar.
Want a knock and boost gauge in there.
Where do you route the wires?
Seems to be a tight fit coming up and around the dash assembly.
Any danger of crimping the vac. line to the boost gauge?
reply to Paul Clark
Paul, I installed a boost gauge plus an air/fuel ratio gauge in my dual gauge pod, and even if it is a tight fit, the only thing that you really have to pay attention to, is to make sure that the boost line tubing does not get kinked or bent too sharply during the installation. Other than that, the only other things in there are wires for lights and grounds that aren't as fragile as the tubing I referred to, although a little extra care never hurts in making sure so you're not pinching any wires.
'bye,
Claude :)
P.S: pictures available...
