wiring diagram?????????
1QWKPHKR
B & B RACING TUSCALOOSA A
ive bit off more than i can chew! what do i need to make a buick turbo (87 model) run wiring wise. i have a project race car no wiring of any kind all i want is the motor to run . im going with all aftermarket gauges. no lights or anything. i have the motor harness to the ecm and the wireing that goes to the fuse box under the power master into the fire wall ... now what ? what do io need to make this motor run . i have nothing to work with ! all help is much apreciated .....thanks
What kind of car do you have this in?What you have should make it run.I have done this swap in to a malibu with the things you have listed but I used the gn dash and it cranked right up.I also have some spare parts were I just took one apart if you need any thing else.I have a wiring diagram too if you need to make a copy of it.I am in Birmingham so we are not to far apart.
hey great if you will give me a number on you and maybe i could call you tonight and get a little more specific.
thanks a lot! buddy espey
