Turbo6Smackdown
- Dec 31, 2005
Anyone have any of these items? I've had pretty good luck here in the past so I'll give er another try. Need the following:
1. The little grey rubber cover that came on the idle air adjustment screw on the throttle body.
2. A really good condition & complete factory compact spare tire.
3. The two little spring steel clips on the passenger side of the inner cowl. They hold the little tiny vac lines that control the HVAC up against the cowl and out of the way. They're very similar to the little clips that hold the wiper solvent lines up against the cowl on the driver's side of the cowl lip thingy.
4. 4 grey OEM factory valve stem caps. They were the Dill 637's in grey, with the little nips at the end.
