Xfi question
jowy
155
4
18
58
Did I have to change some table when opgrade to roller camshaft. My car dont go over 4100 rpm on change of the camshaft and start pimpim
Pronto
Chaos is a ladder.
Dec 9, 2002
11,854
1,077
113
Nashua, NH
Did it rev past 4100 rpm before the cam change? There is a fuel cut rpm setting in the Global Set Up Parameters window.
jowy
155
4
18
58
did you change the valve springs before you started pimpin?
[/QUOTE
ok am going to check the parameter and yes I change de spring on the heads
jowy
155
4
18
58
Yes I change the valve spring ,rebuild de engine ,,check the valves and new pussrood mesure for the roller lifters
Top Bottom
