Xfi with Xim no injector lights
WSLN 6
Powered by Murphy's Law
Anyone happen to know how many things can cause an xfi box to have no injector lights lit up with key on or cranking?
Connected to can bus and Xim feeding an LS...
Injector lights wont be on with Key On No Start. What lights do you have on the XFI when cranking? You should see Cam and Crank when cranking? If your not seeing those then theres your issue
I do see Cam and Crank, but I think it may be related to my tach feed from my Dakota Digital dash, as the Xfi shows 0 rpm on the log while cranking.
