ShawnR
Fixer of crap..
- Jan 24, 2011
I have been collecting parts for the past few years since I started the restore on my 83.
I considered keeping the original draw-thru system just because it was kind of unique, but it was tired and I was ready for some fun.
The parts list:
Basic 109 block bored .030 over.
Older GN1 aluminum heads
Scat steel crank / 2 steel center caps
Bison's 212/212 Crane cam
Comp 885 Hydraulic Roller Lifters
T&D 1.65 Roller shaft mounted rockers
Siemens 60 lb/hr injectors
IGN1A smart coils
Limited Engineering TA60 Turbo
Weiand 4bbl intake with injector bungs & fuel rail
Holley 4150 Throttle body
36-1 Trigger wheel & hall sensor on the crank
I have an MS3Pro Evo unit that is going to run everything. I have the wiring completed and the engine will fire & run on starting fluid, but I am still waiting on AN fittings for PTFE fuel line. I am hoping to move it from the basement to the garage this weekend and actually try to run it on gasoline with the injectors. Only for 30 seconds or so until I get a cooling system rigged up. I want to do a few full heat cycles on the engine stand before I do the swap.
Megasquirt lessons learned:
the Cam sensor needs a "pull up" resistor for the MS3 to actually see it
The coils / plugs are NOT wired in order.
Do it this way. I thought putting the firing order in the software would tell it what to fire. It doesn't.
A=1
B=6
C=5
D=4
E=3
F=2
I'll update as things advance, but overall I'm quite impressed with the MS3 so far. It has a tremendous support community that seem to know their stuff.
Engine pics and the signal output of the Cam sensor (top) and crank trigger wheel (middle).
The parts list:
IGN1A smart coils
A=1
B=6
C=5
D=4
E=3
F=2
