I will be testing the newest pump, came in 2 days ago....I'm testing a new pump for a system.
@ full voltage the psi is 290.
A real fogger!![]()
You must have some good voltage running to the pump? or you got a better pump than I did?Just tested last night.... My new pump does 180 range engine not running. I didnt try starting engine.
Just whatever voltage the battery had. Installing the same pump on a friend's car soon. Both were brand new and direct from Julio. We are going to check his pressure as well. I will report back with our findings.You must have some good voltage running to the pump? or you got a better pump than I did?
interesting. mine is a new pump from Julio as well, but I could only get 180 PSI if the motor was running and my scanmaster read 14.2 volts.Just whatever voltage the battery had. Installing the same pump on a friend's car soon. Both were brand new and direct from Julio. We are going to check his pressure as well. I will report back with our findings.
My engine was not running. I took a video but I'm sure I cannot post it.interesting. mine is a new pump from Julio as well, but I could only get 180 PSI if the motor was running and my scanmaster read 14.2 volts.
was your engine running when you tested your pump?
Why are you spraying Alky on the two step? Just curious... If you apply ground to the purple wire, the alky system turns off. Huge help with spool up.I haven't connected the pressure sensor to the new Alky pump pump yet but... My AFR went to 8.8 on the 2 step without making any other changes. The new pump that I got May 4th is rated at 300 psi on the label ! I am about 14.7 volts on my log. Julio said that I got the first one from him. It is definitely putting out a lot !
Bryan
