tatman2201
- Apr 10, 2022
I've read all the post available on this situation, specifically with the CS II system.
The stock speakers have been replaced with 2 - 4 ohm kenwoods in the dash and 2 - 3 ohm infinity in the door. The rear are 4 ohm 4x6 kickers same size as stock size.
I'm replacing to blown stock head unit with the New York Retro Sound unit. So here is my dilemma. What is the safest and best way to do this without cutting the stock plugs and wires ? I'm almost sure I need to add a smaller 4 channel amp to run the fronts but not sure how to do that without having to cut and splice. Any insight is appreciated. I tested the new speakers with a MM. Front four are @ 2.0 ohms rear two are @ 4 ohms
