1000MileStylez
Black Sheep
- Mar 25, 2003
1986 Buick Regal and whole lot of extras. Open to offers.
Car weighs 3210lbs w/o driver
Engine
Machining performed by S-K Speed,Lindenhurst Long Island
109 block .020 over
JE Forged Pistons
Crower 4340 H beam rods
Eagle crank internal balance
Comp cams hydraulic roller 218/212
Morell lifters
Champion GN1 aluminum heads
Scorpion 1.55 roller rockers
ARP head studs
ARP main cap studs
All 4 billet main caps
RJC 20 bolt Girdle
RJC deep sump oil pan
Ported polished stock intake
70mm Throttlebody
Keith Mease plenum
1in spacer
JW flexplate
BHJ balancer
Meziere Electric water pump
Champion Alternator bracket
TR6 Ignition
HR Parts poly motor mounts
TA performance ported front cover. HV oil pump and regulator.
Precision T72 gtq .75AR 4 bolt
50mm wastegate
Tial 50mm BOV
3.5in 1/8 intercooler tubing
Precision 4in core front mount intercooler
Stainless headers
4in stainless Down pipe
Front suspension/Brakes/Steering
Globalwest upper control arms with brass bushing on pass side
Moog coil springs
QA1 single adjustable shocks
Energy suspension end links, lower control arm bushings
Bell tech 1.5 drop spindles
Spohn sway bar
Weld draglites 15x4
SSBC front dual piston calipers
Manual steering box
Brand new steering linkage
Jeep steering shaft
Rear suspension
Belltech 2in lowering springs
UMI upper and lower adjustable control arms. Rod end style
Spohn rear anti roll bar.
10 bolt 8.5in GN rear
Moser 33 spline c-clip eliminator axles
Moser spool
Strange 3.42 gear set
Strange main caps
TRZ style lower control arm mounts
Welded axle tubes
TA performance rear girdle
Speedway motors rear disc kit with parking brake.
Weld draglites 15x10
Drivetrain
Janis transmissions stage 2 th400 reverse body with trans brake.
PTC 9in 4500 stall
4in Dennys aluminum drive shaft
Moser 1350 yoke
Energy suspension poly trans mount
Body/Interior/Exhaust
Fiberglass cowl hood, trunk, bumpers
Aluminum bumper supports
Aluminum radiator core
Aluminum front wheel wells
Power windows
No wipers
Aluminum door panels
10 point cage with window net
5 point harness drivers and passenger
Kirkey aluminum seats with seat covers
Aluminum dash and gauge cluster
Custom center console with F Body parking brake
New interior carpet
Drivers swing out kit
Fire extinguisher
VDO gauges
Flaming river battery cutoff
GForce transmission crossmember
Aluminum battery box
Optima battery
DOM custom parachute mount
RJS parachute
3.5 single exhaust. QTP electric cutout
Painless chassis harness
83 Regal tail lights
Monte SS mirrors.
B&M quicksilver shifter
MSBC1 boost controller connected to shifter.
Grant leather steering wheel
Brake line lock
Custom oil catch can
Fuel System
Aeromotive eliminator fuel pump
-12 Aeromotive filter before pump
-12 welded onto 15gal fuel cell to pump
-10 SS braided lines to -10 Aeromotive filter before injectors
Racetronix 120lb injectors on motor
Spare set of Racetronix 96lb injectors
Aeromotive Eliminator regulator
Engine Management
Classic FAST
Caspers custom standalone engine harness
Spare parts
3 sets door glass
Header panel in good condition
Interior trim
Custom laser wheel alignment system
Custom wheel adapter for properly balancing weld wheels
Mock Transmission (to keep engine level)
Engine hoist
Engine stand
Caspers cam setting tool
Windshield and rear window trim
Steering column spare
Steering column lock
Bucket of assorted AN fittings
Spare 83 tail lights
Car needs body work. Has single stage black on it. Not a show car at all.
Asking 35,000
Never dyno never tracked so don't ask.
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
Engine
109 block .020 over
JE Forged Pistons
Morell lifters
ARP head studs
ARP main cap studs
RJC 20 bolt Girdle
70mm Throttlebody
Keith Mease plenum
1in spacer
JW flexplate
BHJ balancer
TR6 Ignition
50mm wastegate
Tial 50mm BOV
Stainless headers
Moog coil springs
Spohn sway bar
Weld draglites 15x4
Manual steering box
Jeep steering shaft
Rear suspension
Moser spool
Strange main caps
Welded axle tubes
Drivetrain
PTC 9in 4500 stall
Moser 1350 yoke
Power windows
No wipers
New interior carpet
Fire extinguisher
VDO gauges
Optima battery
RJS parachute
Monte SS mirrors.
Brake line lock
Fuel System
Engine Management
Classic FAST
Spare parts
3 sets door glass
Interior trim
Engine hoist
Engine stand
Asking 35,000
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
imgur.com
