SignUp Now!Yeah, not individually. I am trying to find the entire VLOM. Two are available on ebay at a 100%+ plus mark upI worked on the equipment that made those plates at GM Rochester and those are the early version . I'm not sure you can replace individual solenoids because of the way they are " wired " or should I say hydraulicly riveted to a + & - buss bar ., then flow tested .
Do you know what the part number is, I want to make sure I am looking for the correct thingThey are on a massive back order at the dealer last one I installed took a couple months to get.
We discussed that filter, I am not sure if they changed or not. With one of the selinoids ohming differently than the other 3 we are hoping that is the problem. While apart I will make sure they change it. I just can't find a new VLOM, other than one on ebay for an outrageous price of $800Shane, my "SWAG" is the VLOMS are the same for the different brands.
If you haven't seen the TSB on the issue, this is the latest I've seen.
Do you know if they changed the filter under the cover?
Is there a NC emissions law you have to pass?
HTH,
Do you know how to delete it? Is there a way to keep the idiot light off?If you don't have emissions test, maybe do away with it?
