Dakota Digital VSS Tach issue
Cape Cod GN
Hi all I wired in a Dakota Digital Dash for the GN. All works great but having an issue with the Tach. When I do a cold start the Tach bounces and will also just cut out completely. Then start again intermittently and keep bouncing then cut out. Then when the car warms up the Tach works fine. I was thinking it was a ground but why does it work when the car warms up? This has been going on for a month now. I have driven it multiple times and same thing each time. I checked wiring and all looks good. Im looking to buy the Tach buffer from DD. Could this work. Just don’t get why it only works after it warms up. Thank you.
You have to use the tach buffer and wire it to the tach wire at the coil pack or the tach wire near the alternator.
thanks. I have a 200amp Power Bastards alternator. I’m wondering if it’s causing the issue until the current overflow cable sends the extra juice back to the battery.
It's not your alternator if you don't have that has buffer you will have all kinds of issues with the tach.
I had one of their buffers go bad and basically lost the teach signal. Ordered a new last year and everything is back to normal.
I know this conversation is old i also have a dakota digital dash that came on the car without stock one of course… im trying to find this green vss buffer and cant seem to locate it. The speed sensor on the dash works fine but its not seeing it in the ecm so it throws a mal 24 code. I got a caspers vss buffer gizmo to hook the digital dash and the oem buffer so the ecm can read it. Im lost trying to find this thing. Any of you guys have this issue
Look behind the black panel that you mounted the dash too. Take it out completely you will see it.
