Street Lethal
Tech Anarchist
- Oct 8, 2006
Soon to be released....
An EBL Flash system for 6-cylinder sequential fuel injection will be available soon. The EBL SFI-6 Flash is specifically designed for boosted engines, it has waste gate control plus a progressive alcohol injection control. Along with the ability to run a 1-bar MAP sensor in conjunction with a 2 or 3 bar MAP sensor. When in boost the EBL ECM uses the 2 or 3 bar MAP sensor, then switching to the 1 bar MAP when not in boost. This provides for the best in driveability when not in boost and the best in engine control when in boost....
Highlights:
* No chip swapping, has Flash memory on board
* High speed data logging
* USB interface to laptop/PC
* Code for the ECM is enhanced with larger tables and added functionality
* What's Up Display provides a Windows based graphical interface along with analysis screens
* Documented calibration tables for the new ECM code along with ECU and XDF definition files (used to edit the calibration tables)
* Hardware is industrial temperature specified and conformal coated for reliability and long life.
DynamicEFI
Highlights:
DynamicEFI
