- Jan 18, 2011
Damm i was actually waiting for the results lol... re-schedule soonGot rained out. Was literally backing onto the dyno and it started pouring![]()
The event was completely rained out, they’re working on rescheduling the dyno for another day already. I’ll get some numbers…Damm i was actually waiting for the results lol... re-schedule soon![]()
A lack of head studs is about the only thing I'd be leery of at that level, the stock pistons should be fine. Just don't let it knock. A bottle of VP octanium unleaded would be good and cheap insurance. Subscribing for results when you reschedule. I'd run it how you drive around on the street though JMO.It’s gonna take everything in me to not put a bottle of octane booster in it and turn it up to like 32 psi. Don’t trust the stock pistons. I’ll try and command a lockup in third at the lowest mph I can and test it on the drive there.
Yeah, I miss the old NEBRA meet-ups too. I tripped over a pair of GN wheels the other day I bought from Brian at one of the picnics at his house. Always a lot of fun.I lied.
After several hours of searching the basement I found the printouts. Being a retired hoarder has its benefits.
425.4 HP and 501.8 TQ and that was at 25 psi. per the notes.
Best part of that day besides the numbers, were Brians' ie. "Wagons" scallops wrapped in bacon on his grill.
I miss NEBRA, and of course all the work he put into organizing events for us New England guys.
Found a pile of timeslips too, most good for a laugh at how bad I drive 60ft. etc., but a few I'm gonna frame.
PS: Don't keep your foot in it past 5000 rpm's, there's not much power up there....![]()
You dont need heads cam to make more power379whp. Time based run lol. So I don’t know the torque. But calculations say around 540tq. Correction was set for a 85° day with bad air, and the DA was insane and it was 60° so it probably made around 400wheel hp. Red run is unlocked converter and blue is trying to lock it but I didn’t mat it so it unlocked a couple times. I’m happy. But it’s time to get a cam and heads as the power instantly falls off lolView attachment 394897
Me and my gf lolCool.
Why do you have a picture of Johnny Depp and Amy Locane on your key chain?![]()
I’ll post the powerlogger file in a few. I’m overpowering the converter. Flashed right to 5100 and held there and then ran to the 5600 limiter. Tickled 29 psi on the hit and settled around 27-28. 17° timing and a 10.7:1 afr at wot lol. Tried to lock the converter on the second run(blue) but it unlocked because I lifted slightly and ruined the run lol. There’s always next time. I’ll get videos and logs posted in a bit. Oh I made more HP than a heads cam ws6 TA and a cammed 5.0 mustang. Highest tq out of everyone by a lotYou dont need heads cam to make more power
You need better fuel.
More boost less timing
Or less boost and more timing.
You will make alot more power if the boost is raised and timing/afr is adjusted.
If you wanted to stay in the conservative boost/ range that you are at(mid 20s) on a better fuel you could of added timing leaned the car down and picked up alot more power.
You did well with pump fuel and conservative tune![]()
Not sure if you can look at the log, but I’m thinking I’m about maxxed out on my converters capability. It flashes right to 5100 rpm and holds till the wheels catch up, then it takes a second or two to get to 5600 and done. I’m THINKING I’m overpowering the converter, but what say you?You dont need heads cam to make more power
