Lots of performance and suspension parts for sale
Cleaning out the garage / going a different direction. All prices are OBO and do not include shipping from 77433. I have more pictures of everything, just ask if you need to see something specific. Send a message or call seven 1 three 5 one 6 - five 701. Thanks.
HBC Boost controller ($100)
Old School Kenne Bell Front Mount Intercooler ($300)
Intake tube / LS1 MAF / Air Filter / MAF Translator Gen 2 ($400)
Up pipe for Alky ($50)
PT67 Turbo (4” inlet / 2.5” outlet) ($500)
1984 GN stock 200-4R ($500)
Complete 86-87 wiring harness ($500)
Moser 28 spline axles ($250)
UMI upper and lower rear control arms ($400)
200-4R (billet input shaft, Billet drum, rebuilt pump) ($1500)
Circle D 9/11” 3500 stall convertor ($350)
Impala SS alternator ($50)
Stock ECM w/ Powerlogger and TT chip ($250)
Scanmaster ($50)
PLX wideband ($100)
TE44 ($400)
Stage 1 heads (6293 casting, larger valves, ported by Greg Good) ($1100)
Stock 8445 heads (larger valves, valve job, mild port work by Greg Good) ($500)
Stock 8445 heads ($100)
ATR 3” SS downpipe w/ external WG ($150)
Tial 38mm Wastegate ($100)
Stock intercooler w/ shroud ($150)
T&D roller rockers ($400)
Intercooled complete engine ($6500) (forged pistons .020 over, stock rods, stock crank, steel center mains, RJC girdle, ARP main studs, ARP rod bolts, 215/220 Roller cam, Morel lifters, Rollmaster timing chain, Roller cam button) + T&D 1.55 roller rockers, Buick Motorsports valve covers, Champion CNC heads, APR head studs, Champion ported lower intake, APR stainless steel intake bolts, RJC power plate, ATR headers, RJC deep oil pan, 60# injectors, Caspers Injector harness, H&R poly motor mounts, Adjustable FPR, Aluminum vacuum block, Corvette ministarter
1984 GN roller (SPC front upper control arms, LS1 front brakes, powdercoated lower control arms, SPC springs, Bilstein shocks, jeep steering shaft, Dodge Viper front seats, Southside machine lower control arms, 8.5” 10 bolt w/ posi, new carpet, reconditioned center console, aluminum radiator, Intrepid fans) ($6500)
Sent you a text on the motor mounts, if willing to split the engine package
Do you still have the Stage 1 heads, if so how much shipped to Denver 80220...You can text or call me @ 720-771-3089
