Jon Early
- Dec 4, 2014
I learned a little trick for tackling the warps in my header. It was pretty banana shaped when I bolted it to the head, but I torqued it down and heated the welds with a map torch for a few minutes. After letting it cool all the way down, I torched them again. Once it cooled again, I pulled the bolts out and the warps were almost gone.
The belt sander will be able to handle the rest.
Since the headers were done until I could bring them to work, I shifted my focus over to my nasty timing cover. On a parts store run, I finally managed to pick up an engine degreaser that I like. At only $3.99/can, this stuff makes oil and loose paint fall right off. Best of all, I can actually use the whole can without losing pressure. CRC is losing my business because of that.
Anyway, it looks like my oil pump has relatively normal wear.
I think cleaning, packing with Vaseline, and sending it as-is with a new gasket will work just fine. Speaking of gaskets, I wish I had pictures of the mess I made removing the original timing cover gasket. I've never seen a paper gasket get so gross and tough to remove. I needed a surface prep pad for my die grinder to get it all off because the fresh razor blade was worthless. I'll clean the cover in the parts washer at work and see if I can get it powder coated satin black.
I'm probably going to skip powder coating a lot of parts like the intake and valve covers. I have a feeling that I'm not going to like the results, and having every piece done along with cleaning and masking is going to get incredibly expensive anyway. I'm just going to take care of the essentials. The timing cover needs it, and I don't think I'm going to get paint to stick anyway. The only dilemma now is figuring out how I'm going to get the tensioner to match everything around it because that has been driving me insane!! Does anybody have a used original one for sale or trade? I can't remember where I got this reproduction piece. It's almost brand new. I just hate the color.
![Thumbs up :thumbsup: 👍](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44d.png)
