based on the combos i have seen
Sam's 69mm hubless turbo will probably spool /initially lite just off idle and have extremely low backpressure even in a 3 bolt,
With the ability to max out a 3 bolt ex housing (would need a 4 bolt to realize max flow)
His previous ctr triple bb 67mm spooled up in .3 and made 990hp
With a backpressure ratio of 1.8 on an .85 bolt buick housing and requiring very little tps to do so
![Smiling face with sunglasses :sunglasses: 😎](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png)
That turbo wasnt done
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
This is what matters to me.
Initial spool and the ability to target specifically where I want the power
And how fast it hits max power.
All while having the least amount of backpressure which has major advantages (which is another topic)in longevity of the motor and turbo system and the way the car can be tuned.
Forget spending seconds to wait to spool on a transbrake.
Transbrake if one wishes
But these turbos will go right off the footbrake with very little tps and make boost even if going in and out of the throttle.
tuned a 73mm ctr triple bb that makes boost at 2900rpm on a stock stroke 109 and could be lit up faster if it was needed
