Wondering if there is anything I can do to keep from going into PE while on the 2step. Got it set for 3000 rpm. If I go on the 2step and load it up, I need to keep the throttle so it's just past the point where rpm is limited. If I go any further with the pedal, it starts popping( almost like spark is being blown out). In one instance it killed the engine and took a bit to get it re started. Seems that it does this just after going into pe. Got a wire going to ecm disabling closed loop while on 2 step also.
Sent from my SM-G930V using Tapatalk
