HelloBozos
A Bozo in Buick
- Feb 9, 2011
I had this Build Totally designed to put my 87GN factory motor an heads in the 10's...
Build spec. best to my memory:
Factory Numbers matching 109 with billet mains
Stock rods,crank,an TRW forged pistons
Larger valve's Factory Number matching ported heads (by Boyde)
Ported stock intake,70mm TB
218 comp cams roller,1.65 TD rockers
TE48 turbo/22psi boost
BGC SLIC stretched an large mouthed
50lbs inj/XPR1 Red's single intank /hotwire/red's voltboosted
Number matching billet 200r4,9" non-lock 3500stall art carr
Currie bolt-in 9" 3:50 gears ,28" e.t. street tire
Stock ECM,Extender extreme custom made chip,Translator Plus on 93/Alky
Dyno tuned at 515rwhp at KDK Perf, Orlando
The Car was a Rocket!! Then at round 100mph just into 3rd Gear the Car falls on it's face consonantly .I or KDK never got the combination to run right on top end no matter what was tried. At the track it ran 11.4 119mph,1.98short,7.4 99mph 1/8th. Goodbye FELPRO head gasket (only 22psi) Video below...
This was street peddled pass i tried to get my own kind of log on the car,Watch the Accel/Hp numbers. I let out long before the dyno passes,which was likely all causing harm.
If you could get this design to work,Your Car Will Fly!!! an be Numbers Matching Factory pieces Original Build. (Sneaky,Sneaky 10 second car)
I've since gone to a Stroker 109 ,Champ Heads,gt71,72lbs,Xfi build an 3:20 gears,It fixed the problem, no more 100mph whoa's for me! But if someone can get the above to work-out,You'd be very Happy!! I tried many differant things to correct it myself ,too numberous to list,but from New tunes to the Wheel bearings checked for drag an all in between....This was 5 years ago with my build but i'm reading more an more top end spike issues surfacing. Hope this post helps out
