I am proud to annouce i have run 10.50@131 on 94 octane fuel with razors dual nozzle kit! Boost was at 25 lbs egt 1730's and a/f 11.5. This is with the knob at the 6 o'clock postion with the box mounted vertical. I had to take out 25% fuel and its still rich. Looks like i am injecting alot of Meth. I did get 2 degrees knock on the shifts. I think it wiil go 10.30's if i crank it up. How safe that is i am not sure. timing was at 23, intake air temps 60F !! Should i add more timing? and add More meth! and take out less fuel?
