Razor said:I aint going on no diet...
My Daddy said... "Son.. a man must build his best shed over his best tools.."
:biggrin:
Razor said:Inside the intake manifold, in front of the coil pack assy. Rite under the boss that supports the rear plenum bolt.
Thanks..
tta359 said:Julio, I noticed the kpa on the graph is 284. Does your computer system use a different scale? Usually 6.9 kpa = 1 lbs boost. 69 kpa = 10 lbs boost. 284 kpa = somewhere around 40 lbs of boost??? What gives??
ttypewe4jim said:Using the formula in my math book Im geting 41.19 PSI Im looking around online now to see if there is something werid up with fast that I dont know about if so this similey prefectly discribes my reaction when I did the numbers http://www.fuelslut.net/forum/images/smiles/wow.gif (why isnt IMG linking alloud in here )
tta359 said:Julio Yep, Dec. 17 is coming up. I haven't been doing very well. I tore a tendon in my right ankle . I also was in the process of changing some tuning aspects on my car(probably should have just left it alone). Neither have been going very well. I am working only light duty and going to physical therapy. I hope to see you there. I don't know if I am bring the car or maybe have someone else drive it??
