11.79@119 part2
y-hate
Gone In Sixty
Last post i mention that i ran 11.79 @119 with a 2.032, so i made my last trip to the track before removing my torque converter to have it restalled to 3500 my times where (first pass)11.97@120.997 60ft 2.105 25psi (second)11.98@108.62 60ft 2.109 23psi and the rest of the passes was in the low 12 due to popping in the engine ( mass airflow) gone bad.. after the converter is put back in....watch out now...... (10`s) these runs was at 3 psi launches wish me luck:D
whats your combo. what tires, and those are terrible 60 ft. times. I did 1.8 60 ft on street radials , is that the highest amount of boost you can leave w/ because of converter, or traction?
you will be surprised to note that when you get a "decent" 60' time, your mph will be down a bunch....I would say with a 1.6x 60', your mph will be in the 116-17 range.....a faster 60' almost always means a slower mph
you will not go from 11.98 to 10.xx just by a better 60'
I'll guess 11.30's with a good 60' (1.6x) which ain't bad by the way....
