2000 S 10 11" front brakes with new Napa 2 piston calipers (cost 149 each). This is a bolt on with the spindle, calipers, rotor and high performance brakes all assembled. They are still on the car and should be removed this weekend. Since I only use the car for racing, the setup has less then 200 miles on it. A stock GN rim will not clear the calipers but a TType rim will work. Replaced them with a Aerospace 4 piston setup. $300
Jeff
Jeff
