HelloBozos
A Bozo in Buick
- Feb 9, 2011
If it runs without advance and not on all cylinders then you have at least 2 problems there and they probably arent related. I had an xfi chit out on me and would not go into est bypass. I was able to get it to run and idle and drive but the timing was stuck at baseline. Comp couldnt explain why only that it needed a new board. Needless to say i was very pissed that i had less than 50hrs on the box and it did this costing me $800. I actually had sent the box back to them twice for this. The first time they missed it. The second time i talked to the tech. It appeared to only be an issue in the Buick sfi mode.
Thank you for replying..
That's what i'm thinking. XFI just had this box for the 2.0 update an traction control update,It's brand new so i done Everything an bought everything else 1/2 way related to try an fix the problem but the Box...Just my luck it probably got shipped to hard an banged around. Or. you won't believe this, but when i did the slalom test, my out handled the XFI circuitry?, i did set my Q1A's to stiff in the back on one road test, the back end bounced ,heh,Between your wheelieing an my stiff handling set-up, i guess the XFI unit's need to be mounted in a Pillow... I don't know, i wait on Cal again...Its new box or new camshft,dang sure wanting to try box first..
