I have some Trick Flow 120's in my car with BigStuff3 and need the correct offset pulse width numbers so I can try to get my tune lined out.
Thanks Larry
Oh ok. How does a volt booster effect the numbers?
It shouldn't effect it at all. At idle, the voltage doesn't change. At WOT, the voltage is accounted for in the pulse width calculation. More voltage as seen by the computer = less opening time based on what you entered in you graph.
That's just it Joey. I'm trying to figure out what numbers I should put in for these injectors.
I had the tune pretty good when I had the Deka 83's in it. I put these in it and it's all over the place. Now that's it's cold it's fouling plugs. It didn't run too bad when it was hot outside, now it's a mess and fouling plugs.
Big stuff uses an entirely different type of table
Oh? How does it work?
It works the same way. It just has a non scalable voltage
Don't have to. My system is clean. Injectors have less than 100 miles on them since I got them from Chuck.Hmmmm........... Sounds familiar! Send the injectors in and get them cleaned. I bet they are full of debris from the E85 cleaning out those AN lines. Seriously.
Everything from a new tank to the complete A1000 fuel system was new and installed at the same time, and still is low mile. Both filters are clean.
This is how I got this car. Previous owner couldn't tune it. I got and was able to get it close but still had some cold start issues with the Deka 83's.
But I was able to get all the numbers for those injectors on the internet. Where with these I can't find anything, even from the manufacture.
Joey, I will try those numbers and let you know. I have a guy from the bullet that said if I send one injector in he can find out what the numbers are. I just can't believe that nobody has numbers for these or any 120's I can use.
Boy me too.I really hope you get it worked out. I know your fustration. If it's pig-rich at idle, shorten the pulse width from there. I just hope it's not something your overlooking or something we haven't thought of yet. At the very least you will eliminate another possibility. Let us know.
