14 Bolt deep oil Pan
incharge
I am looking for a 14 bolt deep oil pan and a custom oil pick-up tube for a #016 off center stage block. what are my options??
I have two pans- not sure which one im going to use-but the other one will be for sale soon.
The RCJ 14 bolt pan is a nice piece. I ran into a problem with the Cadmium plating coming off:mad: I didn't want to chance having flakes of plating floating around in the oil. The crank/rods hit the baffle and the pickup extension didn't put the pickup low enough in the pan.
I made a long pickup tube out of two pickups.
I ended cutting the baffle out, glass beading the plating off/ rewelding the baffle and powder coating the pan..............and I added a turbo drain -10AN bung.
The part is a good starting point, but not perfect. Still cheaper than a custom fabricated pan.
