toofastforyou
2FAST4U
- May 25, 2001
"Blazer406", first, it doesn't really matters if you use "fronts" or "rears" since only the center pieces are saved and will be mounted into new outer rims with the rear spacing you need. I used some "fronts" because they were all I had, but since "rears" are less in demand, maybe it would be a good idea to use them for that modification...The price I paid included the center pieces sandblasted and black powdercoated. As for the 4.25 rear spacing on the 10" wide wheels, I have no rubbing issues on the frame or the fender lip using the 275-55-16 tires. I did put on a 1.25" spacer just for fun, to see how it would look with the wheel close to the fender lip (which is rolled). I have not driven it yet with that setup, but frankly, I do expect it to rub slightly but all I'll have to do is to remove the spacer or put some air in the airbags, that's all. As for the front wheels, for a nice appearance ask Jim to make them appear as "flat" as possible, meaning for a more narrowed look.
Hope this helps...
Claude :smile:
P.S: I can e-mail you a few pictures if you'd like...Just let me know along with your e-mail address...
Hope this helps...
Claude :smile:
