Evans Ward
Love those LC2/ Y56 cars!
- May 24, 2001
With some hesitation and long thought, I am placing my numbers matching 1970 Buick GS 455 up for sale. The VIN is: 446370G118XXX (I have Xed out the last three digits for security purposes. Should you not know how to decode the VIN, I will supply information that will help confirm this car is a factory 1970 GS455. The first digit “4” stands for the division which indicates Buick. The second and third digits refer to the series in which the “46” on my car denotes the GS455 model. Forth and fifth digits refer to the body code “37” which denotes 2 door hardtop coupe. Sixth digit refers to the model year “0” = 1970. Seventh digit is the assembly plant code with “G” being Framington, MA. The last 6 digits are the sequential production number. The data plate on my car reads:
ST 70 44637 39592 BDY
TR 185 58 H PNT
The engine block code SR is visible between the number 5 and 7 cylinder head area close to the spark plugs. SR is the correct 455/ 350 HP engine code for the 1970 Buick GS455. I have also visualized and verified the sequential production code that matches the VIN on the engine block underneath the power steering bracket on the front driver’s side of block. Some Framingham built 1970 GS cars had the engine stamp in this location. It verifies and confirms a matching numbers car. It is also a December (12B9) 1969 build date so the car has the pointed gauge lenses and other things associated with an early built ’70 GS car.
I purchased this car in 1998 from a fellow GSCA club member in South Carolina. It was a solid, restored car but needed some TLC on many uncompleted small projects. Over the past ten years, I have come very close to putting this car back to its factory original condition. I have the car mechanically and electrically sound with everything in good working order.
The car drives and runs smoothly and is very reliable. It idles smoothly, drives nicely. All gauges and equipment on the car work as it should. This car has never been raced or abused. I would not hesitate to drive this car anywhere (or distance) in its present condition. This car has won awards in local shows (only shown twice and placed both times) and has always been stored/ garaged and used sparingly by the owner. An added bonus is that I have the original factory broadcast sheet (laminated for protection) which verifies the history and confirms the options and original equipment that the car came with. Car was sold new at Steffy Buick in Ephrata, PA.
Mileage presently shows 126,773 on the odometer. I would describe this car as a very nice reliable driver, a strong runner, and an authentic GS455 that could be used and driven with pride. This car was 1 of 5189 GS coupes built in the 1970 model year and 1 of 5013 built with the automatic TH400 transmission. It has never been raced or abused. I have put 23,000 miles on it total over the last 11 years.
Exterior
Factory original color Harvest Gold exterior paint (code 58 and 1 of 549 of that year in this exterior color) and factory gold full vinyl top. (Code H and 1 of 378 hardtop GS models produced) Very few rock chips, no dents on the body, just a few paint bubbles just behind the rear vinyl top molding. Re: few paint bubbles, I removed the top and trim molding to clean areas/ treated with POR15, then touching up. Overall, the paint job is very nice with a repaint years ago at no expense sparred in lacquer
Straight body with no damage
Very nice chrome on the car all the way around
Correct GS grille with nice correct stainless trim (all intact)
PO5 Code 14 X 7 Buick rally wheels with BFG Radial TA tires, correct 1970 GS center caps
Correct date coded tinted windshield/ glass, windshield antennae
Recessed windshield wipers
Interior
Correct Pearl White bucket seats and interior. One small hole on driver’s side bucket but no major tears throughout the interior.
Original working AM-FM radio with front and rear speakers
Factory gauge package including in dash tach
Power windows
Power Disc Brakes
Tilt sport steering wheel (steering wheel not original to car)
Long console with floor shifter
Air conditioning (all working including compressor but system needs a charge)
Functional rear window defogger
Remote control driver mirror
Map light rear view mirror
Carpet savers (black vinyl with tri-shield emblems)
Aftermarket auxillary triple gauge set (Sunpro/ mechanical) clamped (no holes) under the dash (oil pressure, coolant temp, and voltage)
Original 1970 spare rally wheel and tire that came with the car
Factory Buick tissue dispenser
Engine/ Powertrain
Original and numbers matching engine block/ SR code (27,000 miles since engine rebuild)
Poston 112A camshaft (mild-similar to Stage 1 cam), new lifters, adjustable pushrods
Reworked heads (3 angle cut) with Stage 1 larger valves
Original Quadrajet carb (John Osbourne prepped)
MSD6A ignition module (hidden in windshield cowl), Stinger coil/ pick up, properly set up Crane adjustable vacuum advance unit, Taylor plug wires
Modine 4 core radiator
Correct stock exhaust manifolds, stock cast iron intake manifold, original ram air filter assembly
Correct BA code and original (matching) TH-400 transmission. Has the variable pitch/ switch pitch conversion with 1800 low stall/ 3000 high stall converter (toggle mounted under dash when desired to switch from low/ high stall) Deep capacity trans pan with drain plug
Rebuilt and plated power brake booster
10 bolt 8.5 single track rear end (Olds unit) with 3.08 gearing. (Correct 70 GS 8.2 rear will go with car)
F41 rallye ride pack
New shocks (KYB)
Dual exhaust with “H” crossover pipe
Non-original brake master cylinder on car (1971 type) but original round style master cylinder will go with car (needs rebuild)
I have it currently insured through Hagerty with an appraisal/ agreed value of $26,500. I have priced this GS455 fairly at $21,000. No other offers or trades. If someone is really interested, I may be able to include a few spare parts to sweeten the deal. I also have a clear and free title to this car. Selling to simplify and scale back to maintaining just one Buick along with other interests. I really haven’t used the car very much in recent years so it’s time for it go to a new home, owner, and caretaker. There are several members here that can vouch for the car with condition stated. I have also had it at the Reynolds, GA Buick musclecar event each year since that event has been around. I would be glad to answer any questions for any interested parties. Please send me a private message here off this site and I can supply to you my contact information. I also have many pictures I could send to interested parties.
TR 185 58 H PNT
Exterior
Interior
Power windows
Power Disc Brakes
Engine/ Powertrain
New shocks (KYB)
