forcefed86
- Jul 28, 2005
8.93 @153. Driven to and from the track.
Basic run down...
Chassis
79 rx7 back halfed.
Currie 9 inch with 35 spine moser axles and spool 3.10 gears 29" tires.
competition engineering ladder bars
Front factory struts with power disk brakes
$220 junkyard 5.3 (all orig fastners on rotating assy)
Rings gapped at 26/29
ARP head studs
LS9 GM MLS HG's
Cheap OEM ZR1 Cam
PAC 1218 valve springs.
317 6.0 heads. (slightly hand ported by myself, OEM pushrods)
AEM EMS PNP
120lb injectors
Magnafuel 750 pump
1/2 fuel lines
E85 Fuel
Power glide. PTC 9.5" converter
BW S400SX3 turbo. (75mm) 1.10 AR T4 exh. housing.
Turbo kit consists of stamped SS 98 F-body manifolds. and 2.5" Mild steel piping.
Cheap 12x32x4 Ebay intercooler
9.66 @144 is the best so far only had it to the track twice. Lazy 1.5x 60'. 17lbs of boost Never reved over 5400rpm!
(Will add pictures soon, exceeded my bandwidth on photobucket for the month)
Basic run down...
Chassis
79 rx7 back halfed.
ARP head studs
LS9 GM MLS HG's
Cheap OEM ZR1 Cam
AEM EMS PNP
120lb injectors
Magnafuel 750 pump
1/2 fuel lines
E85 Fuel
