etriebe
- Dec 2, 2008
Just picked this up in march and need to free up some funds for my first home. paid $7500 for car and $1250 shipping from Florida rebuilt the trans and replaced rear springs and added air bags (kirban) All fluids changed p/s, trans, oil, syn rear gear lube, coolant and brake fluid, and new 275/60/15 ET Streets. Ran best of 11.41 In a 1/4 mile no alcohol injection with 22 pounds boost with 110 octane fuel 0* knock. Removed the rags on the breathers and installed different breather grommets so oil wont come out (common issue) Had valve cover gaskets replaced and painted them satin black and polished the Buick so it is sliver again
Motor
-rebuilt
-ported heads
-roller cam
-new pistons
-new crank
-reconditioned rods(shot peened)
-girdled
-cometic headgaskets
-ARP headstuds
-Complete RJC Pulley set
Turbo
-Turbonetics T-67BB
-precision front mount
-turbonetic deltagate
-hallman manual boost controller
-tinman cold air intake
-3" DP(wrapped) and full 3" exhaust
-aftermarket headers and crossover- not sure what kind, very nice
-New Aero high flow Muffler
Trans
-rebuilt w/receipts
-PI vigilante converter
-aluminum driveshaft
-driveshaft loop
-New red alto wide band
-New Billet band anchor pin
Rear
-8.5
-30 spline axles
-c-clip eliminators
-3.42 gear
-ultimate 8.5 diff cover with axle supports
- S-10 wheel cylinders
Wheels
-weld draglites
-almost new M/T 275/60 radials
-new 165's up front
Suspension
-adjustable Konis
-new coil springs
-double adjustable upper and lowers
-H&R torque box support bar
-New rear air bags
-Recent alignment
Fuel
-hotwired 255
-adjustable FPR
-seimens 60lb inj.
-LS1 MAF
Body
-postons fiberglass hood
-fiberglass bumpers
-fiberglass fillers
Misc
-scanmaster
-translator+
-big aluminum radiator
-Turbo Tweak chip- pump gas ,19#'s boost
-New Battery cut off switch wired correctly
-Line lock
-Rear seat brace kit
Motor
-rebuilt
-ported heads
-roller cam
-new pistons
-new crank
-girdled
-ARP headstuds
Turbo
-Turbonetics T-67BB
Trans
-rebuilt w/receipts
-driveshaft loop
Rear
-8.5
-30 spline axles
-c-clip eliminators
-3.42 gear
Wheels
-weld draglites
-new 165's up front
Suspension
-adjustable Konis
-new coil springs
-New rear air bags
-Recent alignment
Fuel
-hotwired 255
-adjustable FPR
-seimens 60lb inj.
-LS1 MAF
Body
-fiberglass bumpers
-fiberglass fillers
Misc
-scanmaster
-translator+
-Line lock
