1987 Buick Regal T Limited for sale or may consider interesting trades. Car is a rust free southern car. Has 125k miles on it. Has ac, pw, pdl, concert sound, power antennae(not working), opera lights, 1/2 vinyl top, t-tops, cornering lights, rear defog, cloth bench seat, cruise, etc. Rust free southern car. Has had cheap $800 paint job to preserve the body until I could afford to have it done right. Looks good from about 10 feet as you can see in the pictures and cleans up nice. New bumper fillers were on the car when I got it. Body is in good shape with only minor scratches and dings. Passenger side outside rear view had been glued back on at some point. Radio is factory unit and sounds like hell, could probably use replacement and a set of speakers. Interior is relatively clean and usable but could use some reconditioning. Previous owner smoked in it and upholstery has some cigarette burns. T-tops leak, create wind noise, and rattle. AC cools reasonably well, but I have never had good experience with a converted system in a turbo Regal. Has new heater core. Engine runs well with no smoke or unusual noises. Usual seepage and leaks from valve cover gaskets, possibly rear seal, etc. Not a driveway destroyer by any means, but does not look like the underside of my Mercedes either. Pretty quick for a mostly stock car. It has a Racetronix high volume fuel pump, adjustable fuel pressure regulator, 160 degree thermostat, gillis valve for boost control, 3.5 inch downpipe, test pipe with dump, Hooker 2.5" dual exhaust system, aftermarket limited slip rear differential, an old but functional cold air intake, pillar mounted boost gauge, center overhead mounted oil pressure and coolant temperature gauges, and probably a few other things I am forgetting. Transmission was rebuilt by previous owner and shifts very positive. No slippage, converter locks, barks the tires shifting into second. Speaking of tires, it has a new set of matching BFG Radial T/A's with only about 1-2k miles on them. IT is missing one center cap. Power master unit is trying to quit on me, the red brake light is coming on for a second when the brakes are first applied. I have a vacuum brake conversion to go with the car that I may get around to installing prior to the sale. The radiator is original and is pretty cruddy onside. I have flushed it a couple of times but the car still runs warmer than I like it to. Temperatures can get up to about 200-210 with ac on and going down the highway at 75mph. I was planning on pulling it out and having it tanked, but never got around to it. I also have a dual fan kit and wiring harness that will go with the car.
Now it may sound like I have described this car as a complete turd. It is not. I want the prospective buyer to have no surprises and rather be pleasantly surprised that the car is better than they thought. It is no show car but a solid car that would make a good driver or weekend cruiser. It is 26 years old, has 125k miles, and is mostly original so plan on doing some repairs to keep it running and looking good. It has had recent basic tuneup including AC Delco spark plugs, AC o2 sensor, fuel filter, Magnecore wire set, and new drive belt. I would not hesitate to get in this car and drive it anywhere in the country. To demonstrate my confidence in this car, I am willing to deliver it within 1000 miles of central NC for free. Asking $7500, will consider REASONABLE offers, may consider interesting trades. Any questions, call or text (preferred as I am not always able to answer the phone) Sharif at 919-697-7262
