jarredsoon
- Aug 9, 2007
1989 Pontiac Turbo Trans Am 733 for sale $12,000
I am selling my TTA 733. Car runs and drives great and looks awesome!!
97,XXX miles on the odometer.
I purchased from Mike Arrigo May 8, 2009 with 78,000 miles
Car is heavily modified, I tracked it back in 2010 it ran 11.6 ET at 115mph (24lbs boost) The last two years it has been my daily driver to and from work and has been a pleasure to drive (18 lbs boost).
Car has been exceptionally maintained because I enjoy working on cars and am not cheap. Oil changed every 2500 miles with zddp.
Reason for selling: I have 15 other sports cars, 7 of which are Trans Ams, 4 of which are '89 TTA's.
List of mods:
MOTOR REBUILT 2012 ($4800)
Stock 109 block
stock oil pan with allen key drain plug
Diamond pistons and rings
Forged crank and rods
206/206 flat tappet cam
Hardened pushrods
HARLAND SHARP roller rockers
CHAMPION PORTED heads (jicaju's old heads he ran 10.0 with)
CHAMPION PORTED stock intake manifold (jicaju)
Chrome 3" up pipe
Chrome maf pipe
Chrome turbo heat sheild
Alky kit single nozzle FRESH PUMP 2013.
Dutt neck intercooler
60lb injectors
Turbo tweak alky chip 5.6
Fuel pressure gauge
Boost/vac gauge
New walbro fuel pump with hot wire kit
New alenator
New radiator
Rjc plug wires
New ignition module and coil (acdelco) (hwy stars)
61mm precision turbo
NEW TRANSMISSION and converter from PTS Extreme ($5900)
Comp trans with dipstick
New trans pump
Shallow pan
Billet forward drum
Billet overdrive planet
Billet overdrive ring gear
Billet servo
Billet input shaft
Bruce's last original new TTA valve body
Billet 9x11 converter 2800 lock up
External cooler
Braided lines
NEW MOSER 12 BOLT ($3500)
3.42 gear ratio
Eaton posi
New forged axels
New housing
New rear brake calipers
New rotors
New pads
E brake works
Chrome diff cover
NEW FLOWMASTER EXHAUST ($600)
New exhaust tips (originals come with car)
3" terry Huston down pipe with dump
New GM power antenna
Stereo works as do buttons on steering wheel
Headlight motors rebuilt
New hawks leather seat covers
Power seats work as they should
Wheels and tires in great shape 245/50/16
Air conditioning blows cold
New rear hatch motor (hawks)
Front nose and ground effects have been resprayed
Needs new fog lamp lens covers but fog lamps do work
After market (hawks) spoiler, no cracks!
After market floor mats
Drive train : 9/10
Interior : 8/10
Paint and body: 7/10
Car is located in Edmonton Canada and I have the Illinois car title
List of mods:
Stock 109 block
Hardened pushrods
Chrome 3" up pipe
Chrome maf pipe
60lb injectors
Fuel pressure gauge
Boost/vac gauge
New alenator
New radiator
Rjc plug wires
New trans pump
Shallow pan
Billet forward drum
Billet servo
Billet input shaft
External cooler
Braided lines
3.42 gear ratio
Eaton posi
New forged axels
New housing
New rotors
New pads
E brake works
Chrome diff cover
Drive train : 9/10
Interior : 8/10
