hmm maybe the experts will chime in .... what are you trying to do specifically?? But I thought the servo piston had to do with the band release?.. Ck's book says 3rd gear oil pushes the servo piston back towards the cover to release the band... So don't quote me on this but is it possible that its the 3rd accumulator hole?? #5 on your diagram?? I'm still trying to learn this stuff myself.....
When you say bind does that mean after it shifts from 2nd to 3rd it noses over just a tad before it changes? I got a little bind in mine & that's the best I can describe it... I don't think mine was drilled. I'm gonna measure to be for sure though.
Also which one is the 2nd servo release hole?
...how do you plug the holes in 5 & 14?
Not bad ttype6 great explanation as you have obviously done your homework,great job,this comes from the hydraulic formula fap which means force is equal to area times pressure which means that if the same amount of pressure is pushing on two separate pistons, but one is larger than the other, the larger piston will apply more force than the smaller one.The other thing going on here that changes 3rd gear timing is the larger diameter aftermarket servo.The band apply side of the servo piston has a larger diameter than the stock GN piston. The release side of the piston remains the same as stock. This slows down the release rate of the band because the difference between the diameters of the apply side of the piston and the release side of the piston aren't as great as they used to be. During a 2-3 shift,the apply side and release side of the piston receive the same amount of pressure. What makes the piston move in the direction that releases the servo? The piston moves because the release side of the servo piston has a larger diameter than the apply side. The same amount of pressure acting an two surfaces that have two different amounts of area will exert more force on the larger surface. Since the release side now has a lesser percentage of increased area over the apply side,the piston moves slower to release the band than it did with the stock servo. So,another possible solution is to re install the stock servo. Using a stronger servo return spring however should get you where you need to be
Heavier than stock 3rd gear return springs help the bind by slowing down the engagement of the 3rd gear clutches. You must use these springs if dual feeding. The other thing we can do,to coordinate the apply of the clutches and the release of the band,is to speed up the release of the band. We accomplish this with the 3-2 mod and by using a heavier than stock servo return spring. Dave can supply you with a heavier return spring. This timing problem is created by dual feeding. Because we are now applying force to twice the area on the direct apply piston,the 3rd clutches apply faster which messes with the coordination of these 2 events. The two things we can do to restore the timing of these 2 events it to slow down the apply of the direct clutches and speed up the release of the intermediate band.
now in saying that,once the 2-3 shift happens, the hydraulic pressure starts decreasing on the apply side and increasing on the release side as the hydraulic fluid has now been closed off on the apply side of the servo. The problem with this is that we have now introduced something in the system that the factory didn't calibrate for which is a larger piston apply area which gives us more apply force on the band for greater holding capacity or clamping force on the direct drum.This is great for us as when we start pumping out more power we need this higher clamping force on the drum for the higher torque output we are putting to these trannies. The issue that we have introduced into the hydraulics part of this circuit is a timing issue,as we now have more force on the apply side of the piston than what gm designed in but the same on the release side, so the way we fix this issue is by getting the fluid to the release side of the piston faster i.e. larger orifice (hole) in seperator plate and or stouter release spring or both,this way we don't get that dreaded 2-3 bind up that everyone talks about.
I'm not really sure what you're asking,as Dave pretty much already answered.The fluid comes in from the manual valve at square hole 8 and from there it goes to the small hole 8 thru a worm passage in the case. This is where it (the fluid)hangs out at the stop light (2-3shift valve) until it's opened by governor pressure where it goes on to become direct clutch oil. From there it goes to 14 small and large holes on your plate,this is where ball #4 is that Dave said to remove because it just gets in the way and restricts oil flow on a hi perf. Trans.From here it moves on to large single hole 14 and into case where check ball #6 sits, from here it's routed to the direct clutches thru center support, the fluid is also routed to orifices #5 which goes into 3-2 control valve passage.and into the 3rd accumulator/servo release circuit.This is why Dave said to deal with holes 5 and14 as these are the only ones of concern, but also where the 3-2 control mod comes into play as the fluid can go a couple of different ways depending on where the 3-2valveis sitting as gov. Pressure controls where the valve is and where the fluid goes this is why it is blocked in a lot of applications and the orifices are drilled and plugged as to not allow it to be variable.I don't know if this answered your question but as stated there is not just one orifice totally responsible for fixing this bind problem,this is why Dave talked about orifices 5 and 14 as they are the important ones.Thanks for the additional information gunzandgearz. It all makes good sense, but can you confirm which hole in the separator plate is related to the release side of the piston?
....I don't know if this answered your question but as stated there is not just one orifice totally responsible for fixing this bind problem,this is why Dave talked about orifices 5 and 14 as they are the important ones.
