Has anyone used a B&M Pro Stick on the 200-4R? I have an Olds Cutlass with a console very similar to a GN. The neutral safety switch and reverse lights are run from a linkage rod going to the steering column. The B&M directions say to eliminate all that and use their switch located in the shifter. It looks like I can mount the supplied B&M bracket then put the original steering rod bracket over it to keep the function of the neutral safety switch in tact. Any comments???
Charlie
Charlie
