So I am going to go with a dual feed then, do you think a treaded plug will be good enough to block the reverse feed or maybe get a bolt with the same thread? I tried getting it welded and they wanted $15 buck for a tack weld....I didn't even ask how much for the exhaust pipe I needed butt welded.
What other improvements is there that I should consider besides the billet parts?
-So far I have the heavier springs in the valve body
-TV valve revised spring and the heavier spring to avoid getting it stuck
-Blocked off 1-2, 3-4 accumulator (based on that when It ran before the shifts were firm but I wouldn't mind a bit more drama, I know its going to be rough on the components but I rather enjoy than baby it)
- enlarged 3rd acc, RND4D3, 3rd clutch, 2nd clutch, RND4 orifice. (wondering If I should go larger on the second 3rd circuit feed which seems to apply on D3 or the same as RND4D3)
-wrapping up the direct clutch dual feed.
-10 vane pump rotor, .500 boost valve, dual spring in the pump slide, hardened rings, heavier springs with sleeve to avoid breakage from rubbing, Teflon bushing and a large lockup solenoid.
-Alto Wide band and red frictions all around with raybestos steels. (kolene seems to be the latest and greatest but not too many fans).
I feel I am forgetting something but just in case. Is there any other mod I should consider?
