The critical components are the vb, governor, servo, and boost valves in the pump. Without these you have a non high performance calibration. Any of the good recalibration kits have the boost valves and servos are available. CK sells a recalibration with a servo. I have a good supply of vb's. I have a few governors. I can supply stock servos also. PM if interested If the trans is out there are a few other area to check but not worth chasing unless the trans will be torn down.
