Originally posted by Chuck Leeper
TV-6. Your MPH indicates you should be in the hi 11's. The 60' time indicates you need some SERIOUS traction improvement.[now over 2.0] W/ that much torque, good suspension and tires, a 60' time in the 1.60 flat area is attainable, and should put the car near 11.90.
I would leave the engine alone for now, and go to work on the suspension and add the 28" tires. Do 1 change at a time and see where it gets you. Don't forget to look at the ft susp too.
Originally posted by c&cgn
Depending on what rim you are using, a MT ET drag 28x9 (which is really only 27" tall) would be a decent choice for you. That should also give you an extra mph or two.
Originally posted by TurboV6
Any updates for me? If I go with the 26 x 10's would the 8" rim be not wide enough? A 10" with tire reccomends a 9" rim.
Originally posted by grey1
So Kevins
Will I loose anything staying w/ the 26's? I'd like to know because there is grudge match racing this Fri. night. I plan on crankin the boost up. But, if I can gain even more w/ a tire change I'll change them A.S.A.P. Thanks, Dave
