RED LS1
SENIOR MEMBER
- Dec 31, 2001
This was a complete short block that had a piston crack pretty bad. The block was never machined before aside from a honing ball on a drill on the passenger side cylinders. It will need to be fully rebuilt and crank cut as metal went through the bearings.
Right now the motor is broken down to the bare block and ready for machining. It's boxed up and on a skid ready to ship. I will include every part to make it a complete short block including
Block
Crank
Main caps
ARP Main studs
ARP Rod bolts
Full set of Pistons and rods. (1 cracked)
1 extra good Turbo piston and rod
Oil Pick up tube
Oil pan and hardware
Blancer and bolt.
Flexpate
$850 shipped to a business address or terminal for pick up. Add $50 for West coast stuff.
I also have many other high performance parts that will be listed if there is a buyer for this. Cam, heads, intake, Turbo, Injectors, Built Trans, Billet converter
Block
Crank
Main caps
ARP Main studs
ARP Rod bolts
Oil Pick up tube
Blancer and bolt.
Flexpate
