3" dp, injector harness, more stuff
Stroker-ace
Boosted-brick
3" SS TH style DP, internally gated, low miles, excellent condition, no test pipe, $325 shipped.
Powermaster unit, functions perfectly, $275 shipped
Adjustable Fuel pressure regulator, Part #6547 on kirbans, $80 shipped
Kirbans Aftermarket injector harness, perfect shape $80 shipped
LS1 MAF sensor: I got 2 of em, $40 shipped each.
Alky kit, cant find a model number, comes with everything pictured, no nozzle, worked fine when removed...$250 shipped.
pm or email strelkom@gmail.com for faster response.
Is the alky kit a known good unit?? Is it missing anything needed to run it other than the nozel??
as far as I know yes... it functioned when it was pulled off the car but the guy had it just spraying into the intake tube without a nozzle. I would reccomend calling the company and getting an instruction manual for it. I also bench tested the pump to make sure it was good. and All i see thats needed for it to run is the nozzle.
is the maf 3/12 inch
I'll measure it when I get home.
i sent you an email regarding the dp the same day you posted it still awaiting a response????
