4.3L GM performance engine
bergy
Turbo Baja
Dyno'ed 500hp. Stage II engine. symetrical port heads. roller cam, corrillo H-beam stainless rods. Chromoly crank. 4-bolt mains w/6-bolt end mains. ARP chromoly stud kit thru out. Dry sump oiling. roller rockers. over .600 lift at the valve with dual chromoly springs. Titanium valves, retainers and chromoly keepers. full MSD ignition to include distributer, blaster II coil, 6AL CDI and wires. This engine was dyno'ed and sold. It has no hours on it. It has all the high dollar go fast stuff on it! It has over 6 thousand dollars worth of heads on it alone! It is a center line crank bore and is an even fire. This is one bad ass engine that will make your grand national haul ass!!!! I want $6500.00 for it and I am firm! This is a great deal and it will cost you alot more than this to build this motor! Call me 360-837-8070 or 503-310-2298 my name is Michael. call me and ask for photos I have any you might want to see. The pictures tell the story!
Michael,
I sent you a couple of questions about your engine when you had it on Ebay but didn't get a response. I was hoping you could tell me if it is an even fire or odd fire engine and what the bore and stroke are.
Neal
Hi Neal,
I posted a reply on E-bay so I am not sure why you did not receive it. Anyway, I would have to measure the stroke and calculate the bore because I do not know the answer right off. It is an even fire engine.
Regards,
Michael
Hello,
If you are talking about the letters CRC on the valve cover I do not know what that means. However, I could find out for you.
Regards,
Michael
Michael, CR is very commonly used as an abbreviation for compression ratio.
Hello,
Sorry, I am terrible at acronyms. The compression ratio I am not sure of but it is somewhere around 13:1 or 14:1. I can find out exactly what it is though!
Regards,
Michael
