I Iceman Go Pokes! Joined May 25, 2001 Jun 18, 2006 #1 Can you change the drive gear with the trans in the car?(The gear on the output shaft) Trans is a turbo 400. Mine has a 18 tooth and it needs a 15 tooth. Thanks
V V6RACER The true 8 Second 109! Joined May 30, 2001 Jun 18, 2006 #2 You should be able to pull the tailshaft housing and get to it.
