If you're familiar with both, I'd like a suggestion for each. I'm sure you're familiar with the GT4788. Do you have any experience with the S480?
Thanks John. I value your opinions very much.
Don the issue you talked about with the adjustment on the gate is showing that the BP is causing it to push open. As far as a T-6 or T-4 I believe Ted is still using a T-4 on his 47-88. Hes well in the mid 8's. I think you can go pretty far on a T-4 with a 224 cu in's with the right turbine wheel and exh housing. Thats why a BP reading would really help you.
BTW: My response sounds jerky, but it is not meant to be. Sorry Laz...
The flu and ear infection are killing me.
Very immpressive, always like watching your car videos too!
I agree with the bp prediction slightly. One thing that will happen is as soon as the gate does crack under the pressure it will be limited to what it was just before it cracked for the most part. You really need to hold the gate shut and use an electronic controller to see the actual bp. It should climb rapidly as it spools and then taper off a little and climb up as the engine speed increases. Once the turbine shaft speed is reached it doesnt take anywhere near as much energy to keep it going as it did to get it spooled though it will still continue to increase as the engine speed increases.Remember, I'm not even using the max (29.9 psi) spring package in the wastegate AND it's cracking open. To me that makes me think it's a relatively lower bp. It's fun guessing on this.
Bison, I appreciate the advice. I'm already using a pretty big shhtick in the motor. A lot bigger than everyone would think is needed. I originally spec'ed the cam to make up for the deficiencies of the heads and make the most of them as they were. Granted, the target hp level back at the beginning was around 800 hp, not 935, and certainly not 1234. Gosh, I'm still running the original 1.835 int. and 1.5 exh. valve sizes.
I calculate I'm pumping about 84 lb/min airflow. Real close to the limit for the T76, but not quite over it. For those getting their calculators out, that's 11.1 hp per lb/min airflow. I'm getting about 10% more hp for each lb/min airflow because of the methanol.
I can verify that the engine simulation software I use has been right on, up to this point.
I've been playing with the turbine housing a/r size on the engine simulator. Don't have a T6 housing to measure, so I'm guesstimating that the radius dimension for the a/r calculation is 4.79". There is a much larger nozzle size difference from one a/r size to the next with the larger T6 housing radius.
This is what I came up with:
.96 a/r = 2.42" nozzle diameter.
1.08 = 2.57".
1.23 = 2.74".
1.39 = 2.91".
When I plug in the .96 a/r, full boost (45 psi) by 6000 rpm.
With the 1.08 a/r, full boost by 6500 rpm with a slight reduction in the maximum level of boost, causing a drop of around 45hp. A drop in turbo shaft speed is responsible for this.
With the 1.23 a/r, the boost level never attained even 10 psi up to 7800 rpm.
Didn't even try the 1.39.
The simulator showed a maximum hp level when using 2.5" for the nozzle diameter.
Does anyone have a T6 housing they could work with me to get a truer radius dimension? Pwease? :tongue: Talking about a Garret housing.
I think I understand what you're talking about. What I've noticed as I've been stepping up the spring package and the boost level, is the boost would climb steeper with each increase of the spring preload. With the lighter spring packages the boost ramp up would have a large roll over as it approached the boost level set by the controller. I am using an electronic controller on the wastegate, with manifold pressure for control pressure. As the springs were made stiffer, the ramp up would get steeper and the point at which the boost level was reached would get sharper with less of a roll over into max boost, but with no over spiking. Once I felt comfortable with the ramp up rate of the boost, I started to up the boost level, starting at 26 psi. As I started going over 28 psi, I started seeing the boost dropping with engine rpm. I would reach max boost by 6200 rpm, then the boost would drop to 28 by the shift point (7,400). After the shift, the boost was back up and it would drop again until the next shift. Then the same pattern again all the way to the finish line. The last try at cranking the wastegate spring tension up resulted in the tires blowing away on the 1-2 shift. I backed it back down, and that's where it is now.I agree with the bp prediction slightly. One thing that will happen is as soon as the gate does crack under the pressure it will be limited to what it was just before it cracked for the most part. You really need to hold the gate shut and use an electronic controller to see the actual bp. It should climb rapidly as it spools and then taper off a little and climb up as the engine speed increases. Once the turbine shaft speed is reached it doesnt take anywhere near as much energy to keep it going as it did to get it spooled though it will still continue to increase as the engine speed increases.
I dont think the simulator is accurate when using the N2O to spool. Like i stated earlier it takes a lot more energy (which the N2O is providing a lot of from all the oxygen) to get the shaft speed up than it does to maintain it. Id think you could spool almost anything with the N2O.
