- May 28, 2001
I pressurized the whole I take side to 20 psi to make sure there's no leaks.
Ok. That tester looks like a nice, have to have, tool...
It works great. Around 7 psi the vacuum block started leaking a little bit. Didn't find any other leaksOk. That tester looks like a nice, have to have, tool...
This is incorrect. I commonly delete the line and use the spring tension and bypass diameter to meter the exhaust pressure on higher hp internal gate applications.The wastegate should never open if there is no line connected to it
How did you verify the puck is sealing against the housing? Is there any weld on the face of the puck?I have the wastegate hole ported to 1.1 inches. I measured it with a dial caliper tonight. It has an oversized puck. I'm thinking of getting a new turbine housing, and a standard size puck. I've pretty much eliminated everything else that could be the problem
There is weld in the very center. I took some grease, and put a thin layer on the puck, then put the dp back on. It has approx. 3/16" solid all the way around.How did you verify the puck is sealing against the housing? Is there any weld on the face of the puck?
How many blades?Ptc 9.5" non lu. Stall around 2800
