I'm not sure how much angle difference you can get by raising the tailhousing before it hits the tunnel, but yes, it would also raise the center of gravity and help weight transfer. Again, I don't know by how much it would help.i was thinking about shimming the trans up to get the negative angle i need. i read somewhere that getting the motor level will help with weight transfer...what are ya'll thoughts on this..........thanks Bob
As long as the jackstands in the rear are centered on the axle housing tubes, he should be OK.Do you have weight on the wheels?? If not you need to go back and measure again...Putting it on 4 cinder blocks is the easiest way I have heard of.
Here's some interesting information on the IC for a stock GN.
Instant center length is -110.3". That's 110.3" behind the rear axle.
Instant center height is -4.8". That's 4.8" below ground level.
Anti-squat is 21.4%. Any percentage below 100% is considered to be squatting (rear axle sucking up into the body under load). A percentage over 100% is opposite of squatting, anti-squat (rear axle separating from the body under load). 100% is neither.
When you did the measurements on your car, was the car lowered below the stock riding height? If lowered enough, that would put the IC in front of the car. Way in front. Like around 550".Don... I've been picking up what you are laying down until this......
Forgive me for questioning......
As I understand it... the instant center is the imaginary line where the upper and lower control arms intersect. This height and forward distance.... in my measurement is out in front of the car..... not behind the rear end......
Please explain.
I'll find my old thread where I measured my car.... and plotted it on Cad....]
I found it....
My Old IC Thread
