i have run a billet bb64 with both a 68 and 65 turbine wheel and the larger cover with a 3 bolt ex housing and was wondering why pte didnt offer the larger cover on their 64.nevertheless,there are 9 sec pte 64s out there and all go faster than low 10s and make more than 18 psi.he compressor wheel can move some air, but only when properly matched with a better flowing turbine housing, the larger H compressor cover (although not offered on the 6466),
rob is making that with a 3 bolt 85.That's what I'm preaching!
Behold!
THE CANTALOUPE!
I don't remember the actual dyno numbers, but memory tells me the test engine made right at 1100.
are you sure?i have seen some backpressure readings off a 900+rwhp buick with a .85 housing and its nothing crazy high,nowhere near 2to1.IMO, 274 - 280 CI is large for a 3-bolt "anything" turbo, in order to maintain proper efficiency and control back pressure, while making good power past 900 rwhp. Sure, some have and are doing it with the 3-bolt housing, but we learned years ago with testing the old school PT88 with the Outlawed "Cantaloupe" 3-bolt .96 turbine housing, what the limits were.
thats interesting.the 3 bolt can support alot of power, more than most guys can create,although alot more are running good motors.'m truly loving that guys are getting a grip on back pressure with the .85 3-bolt housing. Forever, it was the bottle neck with what turbine wheels we had to choose from.
this from what i have seen is an issue3x2 cover.
try co2Im using manifold pressure on the external 46mm gate
cant see you seeing backpressure issues with a 68 turbine wheel it is good for alot more than a 66i also wonder if the 6766 is more efficient over the 6768
at 3950lbs i had a 64/68 large cover 3 bolt .63 housing go 137 at 28psi with iron heads.playing around with the wastegate i could get it to 31psi.after that the turbo made alot more when turned even higher, but i had to seal the gate it shutnow i have been 138 mph @ 3680lbs. with my combo.
doesnt mean it wont go faster.i have seen cars make way more than 2to1 and go faster.it depends on your approach,if you want lower bp you may have to look into other areas.but the 68 turbine wheel is not the reasondont think adding c02 will help performasnce wise....yes it may help with making more boost but i'm already at the 2.1 backpressure..
rob pretty much explained it,also the 68 turbine wheel is quite pricey and is considered an upgrade.you can still get them from tnetics.i run their billet 69mm wheelf thats the case i wonder why they dont offer the 6768 turbo anymore......They only offer the 6766......
they are one big happy family now.Precision began using their own wheels, that is why they stopped using the turbonetics wheels.
cam,headers,ex housing,all areas i would look into if i hit a wall214/214 DLS cam. I have been fighting back pressure with this turbo and it seems to have run out of steam @ 32/33 psi..
Does this mean they are going to phase out the f1 turbine and use the cea?they are one big happy family now.
not to my knowlege,you cant get a 68 wheel in a pte anymore but you can on a tnetics,but in fairness with the 70 turbine wheel from pte you would not need to.after a 70 turbine wheel or 68 f1 comes a 75mm turbine wheel which both offer.but there are all different options out there wheelwise.it seems like alot of them overlap.the truth is they all make power.the tnetics stuff is way underated and the pte stuff speaks for themselves,there ratings are out there and very easy to find they make big power with generally smaller units.Does this mean they are going to phase out the f1 turbine and use the cea?
