i have an 86 gn that has a malfuntioning door lock switch and the linkage is all disconnected from the key lock as well. when i took the panel off i found the door lock switch broken and the plug broken so i need the female plug assembly and some information about how the entire lock system works. the key lock cylender is disconnected from whatever it was supposed to be hooked to and i have no clue as to the how or why of how it works. does anyone have a schematic that shows how the mechanical things are hooked up? and any one have a wiring diagram for the door lock electrics? thank you to whoever can assist me.
